2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2003 impala cooling fans will not start
Old November 25th, 2021, 7:09 AM
  #11
kevinkpk's Avatar
Originally Posted by rocky10954
hi guys , still having problems sorting out my non working fans,
I removed the hook up on the sensor on the intake manifold,
both fans came on very strong.
I then checked fuses [ marked fan cont. 2&3, fan cont1 ]
and exchanged one for the other, no change still no fans.
also no breaks in the fuses, both appear good and not blown.
I then exchanged the fan cont. 1 with fan cont. 2 , no fans
and then test both relays in the crank relay position on the upper fuse box
all relays tested as much as my limited know how could go, I am lost
cam someone pleas assist me on how and what to check next ??
please post
happy holiday. many thanks, rocky
It's not fuse, or wiring or relay. IMO it is the sensor. Are you sure the fan(s) should come on? I know or at least in most cases with ac selected on, it will also signal one fan to run.
Old November 25th, 2021, 10:28 AM
  #12
rocky10954's Avatar
hi kevin , I place the AC on , hear the pump , but no fans .
how do i test the sensor ??
also where is the sensor ??
sorry i am old school.
many thanks, rocky
Old November 25th, 2021, 10:55 AM
  #13
kevinkpk's Avatar
many thanks, rocky
Look for a wiring diagram online. I found one for your car, but the font is too small. Looks like it ties into the pcm, and the pcm selects output to the fan(s).
Old November 25th, 2021, 3:20 PM
  #14
rocky10954's Avatar
hi Kevin , i am not sure when the fan are set to go on,
I have not taken the car on a long drives for fear the fans will not go on,
short trips, i smell anti freeze ,
so far in this fall/ winter tempature the car has not been above 220.
a new used car, for me
Old November 27th, 2021, 3:37 PM
  #15
rocky10954's Avatar
hi guys , me and the impala took a trip over to the auto parts
store , they ran a scan and two codes popped up P0118 & p1115 ,
they suggested i replace the sensor, I did still no fans .
does the computer have to reset after a repair ?
if so how long does it take to reset ??
please post, have to get this car going.
many thanks, rockie
Old November 27th, 2021, 5:23 PM
  #16
kevinkpk's Avatar
many thanks, rockie
Disconnect the battery for about half an hour, hook it back up, clear codes, and go from there.
Old November 27th, 2021, 6:25 PM
  #17
rocky10954's Avatar
hi kevin, will try again tomorrow
Old November 28th, 2021, 11:31 AM
  #18
Impala-Blue-2.'s Avatar
You have checked everything else, have you considered that the fan itself is bad ? Unplug the fan and connect directly to 12V and see if it spins. Easy check.
Old November 28th, 2021, 9:02 PM
  #19
rocky10954's Avatar
hi blue , yes , i removed the sensor wire plug and the fans come on ,
I was doing additional tests only the hood latch is now jammed.
I had hoped disconneting the battery would reset the computer , do not know'
also i donnot know what temature the fans are to start ??
now cannot open the hood,
Old November 29th, 2021, 6:31 PM
  #20
I own a newer Impala (2014 3.6L) and have noticed that when the A/C is not on and the weather is colder that my fans will not kick on until it hits almost 220 Degrees. This is with the car not moving just stationary and idling for a period of time. When they do turn on it falls back to 185 degrees very quickly. Both the the codes you listed are cooling system related stating erratic information the pcm has received from the coolant temp sensor. If you have not already replaced that sensor, i would replace it as it seems to the the culprit.
woganm
October 28th, 2014 11:14 PM
thomasng
June 25th, 2013 8:50 PM
LatinPride613
February 15th, 2008 7:50 PM
ImpPride
January 17th, 2008 6:54 AM
Quick Reply: 2003 impala cooling fans will not start
