2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2004 Impala Temp Gauge High
Old Apr 30, 2012 | 1:06 PM
whiskeywarden's Avatar
Default 2004 Impala Temp Gauge High
I have a 2004 Impala (police package) with 127k miles. It just passed inspection and I took it out today. Everything was fine until I parked. When I got back in (sat for 8 mins) and turned it on the temp gauge went right up to just below the highest mark. I then turned off the car and started it agian and the gauge went all the way past that mak and almost straight down to the bottom of the gauge.
I had no engine light on and the heat and AC worked fine. The car sounded the same also. The only other thing different is that the fuel gauge went down to empty and then crawled up to 1/8th of a tank. I started the 5 mile trip with between 1/4 and 1/2 of a tank. (No smell of gas)
There was no steam, no leaks, no nothing, everything seems to be fine with the exception of the gauge.
I am letting the car cool down before I check the antifreeze but I know it was at the right level because the dealer I brought it to for the inspection toped everything off and is very happy to tell you everything that is wrong with your car. Like I said it just passed inspection without any issues and this was less than 10 total miles ago.
Any thoughts to why the engine light did not go on? Does the fact that the fuel gauge also changed have anything to do with it?
Old Apr 30, 2012 | 2:15 PM
Could have been an air pocket in the cooling system. Could have been a loose wire. You will have to drive it more to get a feel for what is normal for this car in reference to the fuel gauge. I would never make a judgement on a car on only one drive if everything looks normal.
Old Apr 30, 2012 | 2:37 PM
I hoping that is the case. The antifreeze was a little low but still in the plastic container. When I turned it back on The gauge was not as high (still above max) but I noticed that if I turn the car off and on (no engine start) mutiple times the gauge went down each time. Once I got it to zero I started the car and the gauge read normal. I will take it out tomorrow again to try again.
I did check the oil and it is clean and clear of any antifreeze.
Old May 1, 2012 | 8:58 PM
cleveland63b's Avatar
if theres air in the system when a repair wasn't made you have issues
otis_xing
Apr 13, 2013 2:31 PM
mattdez
Apr 2, 2010 2:21 PM
2004MaxxLT
Mar 21, 2009 10:24 AM
Mauler
Mar 2, 2009 6:40 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
