2005 chevy impala stutters, wants to turn off while stopped at light. FUEL PROBLEM
Hey guys. I'm in such a stressful situation. Recently. I filled up my 2005 chevy impala. I drove it to my mother in laws (normal Sunday) and the damm thing starts stuttering and shaking like hell and it actually stalled on the road 2 times. I've gotten 3 different mechanics and 1 shop to look at it. To start off it
******THIS PROBLEM ONLY OCCURS WHILE MY FOOT IS ON THE BRAKE STOPPED AT A STOPLIGHT OR STOP SIGN******
Has 88,000 miles
It's a 2005
1st mechanic said automatically it was the fuel pump
2nd mechanic changed:
All Spark plugs
New air filter
New wiring
New alternator
Took out my aftermarket alarm thinking that was it... Nothing
Doesn't stall but still stutters and feels like it wants to stall...
3rd mechanic / shop
Said it's a fuel problem
Says fuel pump and filter is fine
Changed my fuel sensor?
And flushed something to do with my throttle? Perhaps throttle fluid
He then told me tonight when I picked it up to test it overnight. Tested it and on the way home, drove well, I was very happy. Went to dinner and sure enough stuttering again smh.
Anybody have any idea what I got left to check or any imput on what it could be please? I spent well over 1,000 and it just doesn't seem like it's getting better smh. I'm very concerned. Thanks
Has 88,000 miles
It's a 2005
All Spark plugs
New air filter
New wiring
New alternator
3rd mechanic / shop
3rd mechanic / shop
3rd mechanic / shop
Do you have a receipt or invoice for the work performed by the third mechanic? It's imperative that they changed your fuel sensor with an OEM unit (I believe that it's an A/C Delco unit and runs $50 at gmpartsgiant.com). Verify this with the third mechanic that worked on your car and if they happened to change the sensor then my hypothesis is that the EGR valve on your car could be bad. Inspect the EGR valve and replace if necessary.
Finally, have you considered the possibility that your Idle Air Control Valve is dirty or faulty? A dirty or faulty IACV could cause stumbling and stalling on vehicles..
I have an 08 lt 3.5 and I have had it in the shop 3 times for the same issues you are having. Each time the wrench said it was the plugs. after 3 sets of plugs, it is getting kinda costly. The next time it happens, I am going to have them do it. At least I will have a warranty for the plugs for 12 months. My car only has 35k on it. Anyone have any other comments/answers for this mystery?
same problem
I'm having the same problem, every stop I make it turns off automatically. I had someone check it and they told me it was my oil pump because my oil wasn't going through so it was clogged and drying up and that's why my sensor is turning off my car so my engine doesn't lock up. So today I will be changing my oil, oil gasket, and oil pump. I will let you know if that works
If the problem only occurs with the foot on the brake, could it be possible the vacuum brake booster (power brakes) is bad? I have seen happen this only twice. I've also had the fuel pressure regulator cause similar problems - hard starting, stumbling on acceleration and stalling. When the fuel pressure regulator went bad on my pontiac, it would stall at the worst time. One time we were almost killed when it stalled in front of a logging truck. The dealer had just told us they could not find the problem. When we went back, thay asked can't you live with it? I replied no we almost died with it. With my 2001 Impala,I was experiencing poor performance and hesitation. The fuel pressure regulator on the 3.8 it had was located right on the fuel rail.
