2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2005 Impala Cooling Fans
Old Sep 26, 2011 | 10:22 AM
solpushcart's Avatar
Default 2005 Impala Cooling Fans
I'm looking for help on a cooling fan problem. The problem is, they don't come on. I've done a lot of internet reading on this and have found that these years of Impalas have quite the problem.
What I've read I have tried. The car has the 3.4 V6 engine. I've tried turning the a/c on. No fans running. Then I read that if you unplug the ect sensor and the fans come on, then the relays are bad. That one worked. So I went down and spent $51 on 3 new relays. The fans worked for a few days then stopped again.
Is there anyone out here who may have a solution to this? I figure the relays have to be going for some reason like the fan motors are bad or something. I know I can't afford to take it to the shop at this time and can't keep buying parts for it. I need to get this fixed as my daughter will be using it for school which will be driving 100 miles a day.
Old Sep 26, 2011 | 11:57 AM
EinST's Avatar
Welcome to the forum. There's a lot more to it than "if you unplug the ect sensor and the fans come on, then the relays are bad" which, unless I'm missing something, is gibberish. First thing, take the connector off the ECT sensor and then make sure there's 5V reference on one wire and ground on the other wire with key on. Often the wire degrades inside the connector and the symptoms improve temporarily after it's disturbed.
Old Sep 26, 2011 | 12:15 PM
Thanks for the info. I assume you are talking about using a meter on this. They sure didn't leave much room for that. Especially with my fat fingers. lol.
Old Sep 26, 2011 | 5:50 PM
EinST's Avatar
Nowadays you can't really do much without a digital multimeter and OBD scanner. At least get someone to hold the negative probe to the battery negative terminal or a known good chassis ground.
Old Sep 26, 2011 | 5:57 PM
kevinkpk's Avatar
Yup, that is minimum.
southsoundtaxis
Sep 6, 2014 3:29 AM
ads_210
Dec 11, 2008 6:43 PM
Silverado02
Dec 8, 2008 12:28 PM
SilveradoLS02
Aug 12, 2008 8:45 PM
