2005 Impala parking brake issues
hello all. got an issue with the parking brake my girlfriends 2005 impala 3.8.
i changed all four rotors and pads all around about two months ago. since the day it was done, the parking brake about hasn't worked. i figured the new rotors were possible slightly larger than the old ones, and the drums weren't catching.
so i took the assembly apart and check it out.
on one side, this seems to be true. everything seems to work properly, just doesn't catch. needs adjusted (passenger side)
on the other, this doesn't seem to be the case. when the brake is applied, it doesn't appear as if the shoe itself is expanding. i took the entire assembly apart and checked it over. cable is intact, spring is still on, nothing appears to be off.
looking at the two 'pins' that push the shoe out: when the shoe is off, i can see these 'pins' push out when the parking brake is applied. however, when the shoe is mounted and in place, these pins don't seem to move at all.
i've tried making adjustments to these pins to push the rotor out more, but they do not seem to expand at all when the brake is applied.
it doesn't make much sense to me - i believe that something else internally has to be broken I suppose, but I just can't figure out why or what may have caused it. i haven't been able to find anyone on the internet anywhere with the same type of problem, and i can't find clear enough break downs of part diagrams to see what exactly could be broken.
please help!
thank you!
please help!
thank you!
SpudmanWP
Jun 11, 2015 7:09 AM
bigb
Aug 12, 2013 8:56 PM
