2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2007 Impala 305 code but can't find problem
Old Apr 11, 2017 | 11:08 AM
  #11
JASellers's Avatar
Originally Posted by V12TT
Is this the SS V8? #5 is the first cylinder on the driver side?
This is the SS V8. However it is a transvers mounted engine. Cylinder 5 is the third cylinder on the right side of the motor. Blow is how I was told the cylinders are in my car.
Firewall
2 4 6 8
1 3 5 7
Front bumper.
Old Apr 12, 2017 | 11:05 AM
  #12
Impala-Blue-2.'s Avatar
I looked up the firing order/cylinder arrangement and the info you have is correct. At this point, I would replace all the plugs, wires and even the coil packs. Sometimes the coil packs can get a hairline crack and even the slightest moisture will make them act funny. By the way, how many miles are on this vehicle ? If near or over a 100K then these items are due anyhow. If the problem still persists, then the issue is defiantly elsewhere.
Old Apr 12, 2017 | 11:21 AM
  #13
JASellers's Avatar
The car has 130k miles on it. I did replace the plugs not to long ago. I have new wires on order, although I don't think it is going to correct the problem since I have moved the wires and coil from this cylinder and the problem is still with cylinder 5.
Old Apr 12, 2017 | 11:47 AM
  #14
V12TT's Avatar
How about another new plug on cylinder 5? You switched the wiring but not the plug right?
Old Apr 12, 2017 | 12:04 PM
  #15
JASellers's Avatar
No I moved the plug, wire, coil, and fuel injector for that cylinder.
Old Apr 12, 2017 | 12:42 PM
  #16
V12TT's Avatar
Then I'm clueless. If #5 is at the end then it could be air or fuel but it's not. I would love to hear the outcome of this issue.
Old Apr 12, 2017 | 1:01 PM
  #17
JASellers's Avatar
Yeah I'm clueless too. There is nothing else left for me to try.
Old Apr 12, 2017 | 1:33 PM
  #18
V12TT's Avatar
Hi. How's about the wiring harness before the coil and injectors? Spray some WD40 into the harness to see if there's a change in the behavior...
Old Apr 12, 2017 | 1:48 PM
  #19
is the misfire constant or intermittent?
throwing this out there as i haven't read the previous posts; is cylinder 5 an afm cylinder?
Old Apr 12, 2017 | 2:34 PM
  #20
JASellers's Avatar
According the to car it's always misfiring. Most of the time the car idles perfectly. It some times had a rough idle.
From what I can find it is not an afm cylinder. Those are 1, 4, 6, and 7.
