2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2007 Impala 305 code but can't find problem
Old Apr 12, 2017 | 2:35 PM
  #21
JASellers's Avatar
Originally Posted by V12TT
Hi. How's about the wiring harness before the coil and injectors? Spray some WD40 into the harness to see if there's a change in the behavior...
WD40 is about the only thing I have not tried. At this point I'll try anything.
Old Apr 13, 2017 | 7:19 AM
  #22
Originally Posted by JASellers
According the to car it's always misfiring. Most of the time the car idles perfectly. It some times had a rough idle.
From what I can find it is not an afm cylinder. Those are 1, 4, 6, and 7.
has the crankshaft position sensor been changed and an crankshaft variation relearn not been done. this can set false misfire dtc...usually random po300.
Old Apr 13, 2017 | 8:26 AM
  #23
V12TT's Avatar
tech2,
On the misfiring subject,
If you have certain cylinder misfiring in idle and also random misfiring in part (low) throttle then does that say anything about the cause?
Old Apr 14, 2017 | 5:53 PM
  #24
JASellers's Avatar
no the crank position sensor has not been replaced.
Old Apr 14, 2017 | 7:29 PM
  #25
tech2,
not sure...
If you have a good scan tool you can monitor the misfire counters live. gm has the best misfire counters i have seen. So although the dtc shows a random misfire at times it not definite that something changed...the scan tool can show you whats going on live....to see if the accumulators count for another cylinder or stay on the same cylinder.
Old May 1, 2017 | 9:04 AM
  #26
JASellers's Avatar
So I took my car to a shop. The wonderful roller lifters are the problem. There is also cam damage too. So I'm looking at a rebuild of the top end of the engine.
