2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2008 Chevy Impala PPV troubleshooting
Old Jun 10, 2019 | 9:23 PM
roverhater10's Avatar
Exclamation 2008 Chevy Impala PPV troubleshooting
Hey guys i need some help in troubleshooting some problems with my impala. Today i got my impala back from the shop which replaced the lower engine mount and the transmission mount as well. I replaced those because the car made a clunking noise in the front end. The clunking seemed to have stopped but i drove it again today and it started to make it again. The clunking is not constant, but it comes and goes. It also makes the noise when i turn hard. Then i started to hear a grinding and clunking noise from the back end. Any idea as to what it could be? Recently i had the rotors and brakes replaced on all four corners, as well as the front outer tie rod ends. replaced the tie rod ends with moog, as i heard those are really good. Any help is appreciated, i am just trying to get my car fixed.
Old Jun 11, 2019 | 10:41 AM
Willking3521's Avatar
Does it only make the clunk when you are accelerating?
Old Jun 11, 2019 | 6:01 PM
It does not matter if i accelerate or not, it still makes it. But it comes and goes away. Steering and braking feel fine though.
Old Jun 11, 2019 | 9:00 PM
front end: check the control arm bushings, sway bar links
Old Jun 12, 2019 | 5:13 PM
Thank you i will do. As for the rear you think it might be a bad bearing?
