2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2009 Impala Parking Brake
Old Nov 5, 2010 | 9:35 PM
klutz1's Avatar
Default 2009 Impala Parking Brake
PB pedal moves to the floor so I adjusted it. Adjustment is easy by holding open end wrench on the lock nut and turning the adjustment clockwise into the nut. The adjustment rod is located near the rear axel. After the adjustment the pedel was satisfied at about 3/4 movement Further adjustment would bottom the threaded adjusting rod. The Impala LT has 28,000 on it. Seems adjustment should tighten the pedel more. Is there another adjustment at the pad itself?
Old Jan 9, 2011 | 8:10 PM
chevy_diyer's Avatar
Hi klutz1, if you came up with an solution to your problem could you share it on this thread? Much thanks diyer.
Old Jan 10, 2011 | 7:56 AM
osbornk's Avatar
I don't think you want to tighten it more and you might have it tighter than it should be now. I think it is supposed to go to the floor or nearly so.
kennyp1960
Nov 6, 2014 10:43 AM
MattDaddyG3
12
Jan 31, 2013 8:25 AM
jbriggs337
Jan 23, 2013 10:42 PM
ahearnep
Aug 20, 2011 11:52 PM
akadeno
Aug 24, 2006 12:58 AM
