2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2009 Impala Steering Column Trim and Levers Removal
Old Aug 19, 2015 | 7:24 PM
mtcjayne's Avatar
Default 2009 Impala Steering Column Trim and Levers Removal
I am attempting to remove the main dash plastic panel from my Impala. The (seemingly) last steps I need to take are:
  1. Remove the steering wheel tilt release lever
  2. Remove the steering column trim
  3. Remove the multifunction lever (turn signals, wipers, etc)
According to a service diagram I should disable the airbag and simply pull out the tilt release lever, but so far I've had no luck. I can try again if no one points out another way to do it.
I need a Torx driver to remove at least the steering column trim. I don't know which size and if someone could tell me that'd be great, otherwise I'll buy a whole set.
According to a service diagram I need to undo fasteners for the multifunction lever. I don't know what kind of fasteners these are as I haven't seen them yet. If anyone else has ideas or knows, that would also be great.
EvansBlue
S10 & Blazer DIY and Useful Threads
Aug 31, 2015 9:43 PM
sixpack_sid
Camaro
Dec 9, 2011 7:53 PM
glenn irwin
Oct 18, 2010 12:12 PM
DanielC409
Jun 16, 2010 12:11 PM
taylorisafop
Dec 19, 2008 4:57 PM
