2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2011 Impala Fuel smell/leak
Old Jan 5, 2016 | 1:26 PM
GJ1's Avatar
GJ1
Default 2011 Impala Fuel smell/leak
I am getting a fuel smell from the engine compartment. Initially there was a leak that left a few spots on the garage floor. Now just the smell. I had the odor problem before and took it in under warranty. Chevrolet found no problem and the smell went away. I assume they tightened something that is a defective part. I had this problem on a 2003 Impala and it was the spot where the fuel line tightens to the injector rail. It was the o-ring, and it's just not a very solid piece of auto engineering. Any thoughts?
Old Jan 5, 2016 | 2:54 PM
jtho53's Avatar
Check the metering valve that goes to the fuel rail to the injectors. My 2005 did the same thing. It was wet with fuel. Not so much the O ring. They leak at the seams.
Have it fixed or you will have a fire dept. call.
Old Jan 5, 2016 | 9:39 PM
cleveland63b's Avatar
did you fix the leak? just because you're not seeing spots doesn't mean it fixed itself.
Old Jan 6, 2016 | 7:28 PM
GJ1's Avatar
GJ1
Thanks for the info. Haven't had a chance to get a good look under the hood yet.
