2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2012 Impala Blend Door Actuator Calibration Question
Old Jun 4, 2021 | 11:57 PM
MCDuffy's Avatar
Default 2012 Impala Blend Door Actuator Calibration Question
Hi everyone! Lots of great info here!
Last week starting getting the clicking noise behind glove box when I shut off my 2012 Impala LT.
I ordered the new actuator and would like to confirm the calibration method.
I have read everything from using a 9 volt battery, scan tool, and a procedure for pulling the fuse and removing the battery cables. Most of them are for earlier year Impalas.
Would someone please tell me the procedure for a 2012 model. I do not have a scan tool.
Thanks!
Old Jun 5, 2021 | 10:49 AM
post a pic of the hvac controls. some gm can be manual calibration thru the hvac controls
Old Jun 5, 2021 | 12:21 PM
MCDuffy's Avatar
Thanks! Hope this helps.
Old Jun 5, 2021 | 9:41 PM
key on, push the a/c and defrost simultaneously 3x? or 5x?....if both lights start flashing...its calibrating
Old Jun 6, 2021 | 8:09 AM
MCDuffy's Avatar
Thanks. I will give it a try before I replace it.
Another question:
Do I install the new one then calibrate it?
Or do I plug the new one in, calibrate it, then install it?
Thanks Again!
Old Jun 6, 2021 | 11:07 AM
install it first....it needs to be inthe hvac box before calibration...the doors provide a stop for calibration....it will move out of range if actuated with no stop. then it will need to be recentered or it won't align for install. w hen centered you should see a centering mark on the case for the master spline
Old Jun 7, 2021 | 6:27 AM
MCDuffy's Avatar
Thanks! I will be installing it this weekend.
Old Jun 12, 2021 | 3:41 PM
MCDuffy's Avatar
I installed it. It took about 45 minutes.
The blend door was closed when I removed the damaged one, I had to open the door to install the new one.
I could not get both lights to flash pushing the defrost and AC buttons. I tried 3 times and 5 times.
It is working and the clicking stopped, hopefully it calibrated itself.
Oxyacetylene
Aug 22, 2016 2:33 PM
lkg427
Apr 2, 2015 1:06 AM
EpicFruit
Jul 25, 2012 4:18 PM
