2013 impala, CD stuck in radio
I have a 2013 impala that has a CD stuck in the CD player on the factory radio. The radio works great but the CD playing light stays on. I have pushed the eject button probably more than 100 times but the CD will not eject. The CD was stuck inside the radio when I bought the car. Last week I removed the radio and removed the face plate and could see the CD inside the load / eject slot. I was able to grab the CD with a pair of needle nose pliers but could not pull it out. Anyone know a way to remove the CD? The reason I removed the radio last week was to replace it with another radio from a 2009 impala. After swapping them the display on the 2009 radio said LOC which I assume means locked and a code is needed for this radio to work. I reinstalled the radio with the stuck CD since at least I could listen to the radio. Any help removing the CD is appreciated.
jso2378 (February 3rd, 2020)
sounds like a win.
keep trying...put the card in and simultaneously press eject and pull the card out.
only the dealer can unlock a radio. you would have to install the radio and take the car to the dealership.
jso2378 (February 7th, 2020)
