2003 Suburban-No Volume from Radio
Old Jan 24, 2013 | 6:49 PM
parkb309's Avatar
Default 2003 Suburban-No Volume from Radio
Greetings,
recently the volume on the radio/6 CD changer of my 2003 Chevy Suburban stopped working (This is not an aftermarket radio/cd changer). Before the problem began occuring, I removed the radio/CD changer in order to remove 4 CDs that were stuck in the changer. I unplugged the battery before taking it out. Once I plugged it back in (all of the wires look fine, everything plugged in properly) I plugged the battery back in.
The issue I am now having is the display on the Radio/CD Changer will show up and it will change when I move the radio tuner (So I assume the Radio/CD changer hasn't been locked). However, there is no audio in the vehicle, no matter how high I turn it up. I also tried plugging in headphones to the back seat audio output, there is no audio on the headphones either.
I checked both of the fuses under the hood (Radio and Radio AMP) and both look fine. So my question is, what is it I have to do to fix this problem.
Thank you for taking the time to read my post, any advice would be greatly appreciated.
Old Jan 24, 2013 | 9:27 PM
Welcome to the forum.
Sounds like it's locked.
Old Jan 25, 2013 | 11:58 AM
parkb309's Avatar
I would have thought that too. Except the display doesn't say "LOCKED." I called the dealership and they told me if it is locked it will display that it is, which it isn't.
Old Jan 25, 2013 | 12:28 PM
Maybe a broken wire or bad connector?
jrsavoie
Jul 4, 2011 6:18 PM
dmoore
Mar 23, 2008 8:54 PM
mrupp4237
Dec 31, 2007 11:33 AM
4th Burban
Nov 26, 2007 1:10 PM
cmmotors
Aug 25, 2007 11:42 AM
