2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2014 Impala bow tie color change
Old Mar 7, 2015 | 11:25 AM
Slimboi's Avatar
Default 2014 Impala bow tie color change
What is the best way to change the color of your Bowtie front, back and steering wheel
Old Mar 7, 2015 | 12:21 PM
sledge.impy's Avatar
plasti dip
or that vinyl wrap stuff or whatever it is.
Old Mar 7, 2015 | 12:26 PM
Head to a forum that is more concerned about such things, such as here:
Black Front bowtie - Chevy Impala Forums
Do a search on bowtie black there and it will also give you more threads to read that will keep you busy for a couple hours.
Old Mar 9, 2015 | 4:05 PM
57chevythunder's Avatar
Just a quick tid bit: I carefully pried and removed the gold insert from the front emblem. (2015 Impala) -don't expect it to be easy. -they used plenty of black rubbery cement kind of stuff to stick it on. Careful application of heat with a heat gun seemed to help. (Honestly, I expected it to break, so had already ordered a new stock replacement, just in case, so now have a new stock one in a box on the shelf.)
Anyway, I just basically spray painted mine satin black. Who knows how that will hold up, but WOW it sure does look nice for now !! (I should figure out how to attach a picture to my profile, I guess) I studied the various paints for quite a while, and finally settled on an "all surface" spray by Rustoleum. I did spend a lot of time gently scrubbing the original gold finish with mineral spirits before heating it up slightly and then painting it with a couple light coats, with the prescribed wait time in between.
I sure wonder what kind of finish the original gold is? I scraped around on the one of the edges to see if I could tell, but couldn't. Whatever it is, man it is really bonded on tight !! -it almost seems to be some type of plating.
Yes I did find an after market black aluminum insert for the rear emblem, but nothing yet for the front. (-actually I just painted the rear one too) I kind of prefer that fine textured (raised pattern) of the stock emblem, so by painting it you still have that original pattern.
By the way, if you are thinking of removing the whole front emblem from the grille to make it easier to work on,,,,, OH BOY. -let me tell you how that works: There are four very secure lock tabs that attach the unit to the grille, and the only access to release those locks are through four holes that have to be accessed THROUGH THE FRONT of the emblem !! -so you have to pry the gold insert out first anyway,,,, Sheesh, what a design,,,
Old Mar 9, 2015 | 5:18 PM
Slimboi's Avatar
Thanks a lot that's what I think I will do yours looks great and a lot more stock than the vinyl stuff
Old Apr 28, 2015 | 7:05 PM
-just curious Slimboi, did you do the color change on yours?
ericseattle07tahoe
Jun 23, 2008 8:34 PM
projekt4
Jul 3, 2007 4:13 AM
dcarreiro
Jun 12, 2007 10:03 PM
massattitude
May 4, 2007 5:51 PM
P_RsTahoe
Jan 29, 2007 4:02 PM
