2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2014 impala lt questions
Old Jun 6, 2015 | 2:47 PM
MMullen614's Avatar
Default 2014 impala lt questions
I took my 2014 impala in today for a oil change and when they gave me back my paper work they gave me my vehicle report. With the warranties, recalls,transaction and etc on it. Well under the section required field actions it has my recall stuff there that I've taken care of. It has a new one. It says service update bulletin, number 14770, sub-seat wire harness-expires with base warranty. Release date 3/25/15.
Do I need to bring it in to have that fixed? Cause I put my vin in on gm recall website and nothing came up.
Also on that paper under the service information it says, type El, number PIE0310, description: poor A/C performance,AC not cold enough,insufficient cooling,A/C not working. Date posted 2/10/2015
Type El, number PIE0329, brake lights stay illuminated without brake pedal being pressed, date posted 3/16/2015.
What does this mean? Should I bring my car in for those also? I have noticed since I've had the car the A/C never really worked as good as I thought it should like being real cold. And with the brake thing I'm not sure if that's the case with my car cause I'm always driving it and can't see.
Old Jun 6, 2015 | 5:42 PM
sledge.impy's Avatar
Thanks. I've only heard about the wire harness thing.
My AC blows cold 35-40F.
Old Jun 6, 2015 | 9:24 PM
Frank3's Avatar
I had the seat harness recall done recently. It basically just involves the dealer checking the routing of the wiring harness under the seat. If it is in the proper location - you are done, if the harness is not routed correctly, they re-route the harness so it is correct. If the harness is left in the position where it is routed incorrectly, if I remember correctly, the insulation can get chafed off of the wires which could lead to un-intended movement of the seat while driving and possible loss of the control the the vehicle. From my understanding, this is only covered under 36 mo 36000 mi warranty.
Old Jun 6, 2015 | 11:36 PM
So.. perhaps another sly way to not notify people and end up with an accumulation of deaths 10 years from now... (key spring tumbler anyone??)...
The old GM is still the new GM?
What does Chevrolet Customer Service have to say about this?
Is there a date for this item?? It could be there was a new person on the job at the time and didn't understand the routing and did whatever was easiest...
MichaelD16
Sep 14, 2015 12:35 PM
2004MaxxLT
May 15, 2014 3:14 PM
Chevrolet Forum News
Jan 18, 2014 11:08 PM
Jan 17, 2014 10:08 PM
blueinterceptor
Jan 5, 2014 8:40 AM
