2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2015 Impala side assist is in-op
Old Apr 24, 2018 | 2:55 PM
aramike1515's Avatar
Default 2015 Impala side assist is in-op
2015 Chev. Impala side assist detection is not working. It started with the passenger mirror not working and now both don't work. This car only has 40k miles. Has there been a recall on these?
Old Apr 24, 2018 | 6:50 PM
impalaltzer's Avatar
A lot of people complaining about this issue. Go to www.impalaforums.com 9th generation.
Most feel it's a safety hazard. It's do the corrosion of the sensor box located under each side
under rear bumper. Unless under warranty, it's a costly repair due to poor design placement of the
sensor box. I've recommended people to write to NTHSA and file a complaint.
Old Apr 25, 2018 | 12:52 PM
I appreciate the impute. I will do exactly that. It is a safety issue. Once you have this, you rely on it. Thanks for writing back
Old May 4, 2018 | 9:15 AM
Frank3's Avatar
I just got my 2014 Impala 2LTZ back from the shop for that. They ended up replacing the modules on both sides and the wiring harness because of water intrusion. Mine had blown fuse # 62 in the underhood fuse panel, which caused additional messages on the drivers information panel.
Old May 4, 2018 | 1:46 PM
That's the cause everybody who has for this problem, because of a poorly designed placement of the those sensors.
People need to complain to NHTSA, as a safety problem due to bad choice of placement of the sensors.
Chevy's just passes the problem as in most cases an out of pocket problem for the consumer.
Old May 4, 2018 | 3:17 PM
Impala-Blue-2.'s Avatar
It is doubtful that it will ever be classified as a safety problem as it does not make the car un-drivable or dangerous to drive. They are safety aids, not a substitute for not paying attention or not using common driving skills. If it fails, you just have to drive it like a car that is not equipped with it, like most people have learned to drive for last 70 years, use your mirrors and check your blind spots with your eyes.
That being said, it was obviously a bad choice by GM to locate the modules in such a location and or not design the modules and connectors for that kind of environment. It could be the supplier of the modules not building them to spec as well. I am considering getting under my car and sealing the module and connector on each side with a Silicone RTV Sealant to try and prevent it from failing.
Old May 7, 2018 | 8:29 AM
Frank3's Avatar
Exactly, I did some searched on the internet, and from what I found, on a Tahoe, those modules appear to be placed inside the doors. A much better sheltered area.
