2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
accel pedal pos located at
Old May 7, 2012 | 11:28 AM
msseburn's Avatar
Talking accel pedal pos located at
Hi I got an code on my car and the code was p2138. I need to replace the accel pedal pos and I dont know where that is located at can you please tell me where I can find that at.
Thanks.
Old May 7, 2012 | 12:44 PM
EinST's Avatar
Welcome to the forum. 2008 Impala (had to look up your profile)? It's too new to have developed an APP sensor failure. There's a TSB for a likely wiring problem. Search for "TSB #07-06-04-019." Unfortuantely it's not easy to diagnose without access to a scan tool and service information database.
Old May 10, 2012 | 10:17 AM
msseburn's Avatar
Default what I need to do
How do I fix the wiring promblem and what does the tsb 07-06-04-019 mean I am an female and I don't understand anything about a car. I just want to get my car fix and that p2318 code is the only thing that is coming up. I just want to get the problem fix please help me.
Old May 10, 2012 | 11:40 AM
EinST's Avatar
The accelerator pedal position sensor is part of the accelerator pedal assembly. There's a wiring harness that snakes down from behind the instrument panel and gets connected to the sensor. That said, I don't think it's something you ought to tackle. I've absolutely no problem with "female" but not so with the "don't understand" part.
Old May 11, 2012 | 10:33 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> msseburn,
I agree with "EinST". If you are not knowledgable about cars, I would recommend you have the vehicle inspected by a certified technician at your local dealer. They will be able to assist you further with this issue.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
craazyfool
Mar 1, 2010 10:21 PM
rvjunior4
May 15, 2008 3:52 PM
Brian_Vesson
Oct 23, 2006 4:25 PM
beaverton007
Nov 14, 2005 11:20 PM
