2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Adjust gas pedal pressure? - 2010 Impala
Old Apr 17, 2012 | 9:47 PM
JimK's Avatar
New User
Awaiting E-mail Confirmation
Default Adjust gas pedal pressure? - 2010 Impala
I'm assuming this is a drive-by-wire set-up so there's no real throttle spring connected to the gas pedal linkage. If so, is there any way to lighten up the tension on the pedal? It feels quite stiff, especially after several hours on the road. The pressure on our GMC Sierra is much lighter and much more comfortable to drive. I'd like to lighten up on the Impala to match the GMC. Can it be done? How?
Old Apr 17, 2012 | 10:14 PM
MDTAHOE's Avatar
Professional Mechanic
Clean the throttle body and see if that helps. If not as far as I am aware there is nothing else. I seem too think that all of the drive by wire cars feel about the same. If cleaning it does not help there maybe some thing else wrong.
Old Jun 19, 2012 | 12:22 PM
ohiobrier's Avatar
I too have the same problem. I have checked to see if there was possibly some kind of service bulletin on this and haven't found anything, the car in my case is a 2010 but I also own a 2000 which doesn't have the drive by wire setup and there is a bunch of difference. BTW I am a retired certified GM tech and I don't remember the drive by wire vehicles being that way but there is a difference in test driving and driving 2000 miles as I just did.
Old Jun 19, 2012 | 2:48 PM
Thad W. Posey's Avatar
I have an 07 Impala LTZ and noticed the stiff gas peddle the day i picked it up from the dealer. The fix is rather easy and I did it within a week of owning the car. Remove the gas peddle, just a connector and couple bolts and it comes out in your hand. There are two coil springs on the peddle assembly. Disable one of the springs by bending the coil spring stop away so the spring can uncoil relieving the spring tension. This works and will make depressing the gas peddle more normal feeling. Why it is set up this way with such a heavy feel is one of the mysteries no one seems to know.
Old Jun 20, 2012 | 8:12 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I have researched this issue in Impala vehicles, however there are currently no known issues regarding a stiff accelerator pedal.
The accelerator pedal position torque may need to be altered. This is just a suggestion, not a diagnosis.
I would advise consulting with a certified technician for an official diagnosis.
Louis
GM Customer Service
Old Jun 23, 2012 | 10:44 AM
ohiobrier's Avatar
I did the spring thing and it works great, I suppose the extra spring would be extra protection should one of them break but the pedal prssure on a long trip is terrible. The pressure seems to be just right now.
Old Nov 28, 2013 | 9:56 AM
69Vette's Avatar
So, is this "hard gas pedal feel" in the 2009 & newer Impalas an across the board issue?
We Are looking to update my wife's 2000 model with a 2010 or newer, but she has an issue with the gas pedal feel being too stiff. This will be a deal breaker, and a waste of time shopping impalas if all of them are like that.
Old Apr 18, 2014 | 1:42 PM
JimK's Avatar
New User
Interesting "rest of the story" on this issue - after having the gas pedal assembly replaced (see my post about "Warning . . .), the new pedal assembly is less stiff than the original. It feels more "normal."
ahearnm
Mar 19, 2023 6:37 PM
caddieb
May 15, 2011 5:32 PM
prancy
Jun 22, 2006 11:26 AM
