2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Air Condition AC
Old Aug 4, 2018 | 1:39 AM
  #11
you must verify the charge level before you do anything else. trying to diagnose an a.c system with a low charge will lead to misdiagnosis.
Old Aug 4, 2018 | 6:27 PM
  #12
20InchBladesOnTheImpala's Avatar
took it to a AC shop and the guy checked the level, then checked it with a meter that beeped at the leak. he said it was the ac compressor housing. he sprayed soapy water on it and it started bubbling. he said all those new parts i changed was for nothing. wont trust my mechanic again lol, well i ordered a new compressor and when it arrives i will be putting it on. ill keep u guys posted on how things go. thank yal god bless u guys.
Old Aug 6, 2018 | 3:01 AM
  #13
oilcanhenry's Avatar
Originally Posted by tech2
the yf stands for your f'ed...the cost for this stuff is $100 a pound
Yeah, pretty much. I guess the patent for R-134A must be running out! I hope it's compatable with R-134A.
I once did a whole rework on an 91 C-1500, swapping R-134 A, instead of R-12. Worked just fine, only 42 degrees F outlet,
instead of 39-40 F.with R-12
Yeah, we are all gonna be pretty much "fooked" when this "new" refrigerant hits the market. Follow the money............
Old Aug 6, 2018 | 12:03 PM
  #14
oil compatibility may be an issue.
Is anyone making a refit kit to change the service fittings back to 134? If not...you have no way convert back.
Old Aug 7, 2018 | 4:10 PM
  #15
i should be getting the compressor this week. is there anything i should be doing in the process on putting it on? on the ad it says it was pre oiled but i should dump it and refill it with correct amount. i have pag oil in the system already from the previous installment. how do u dump the system of the old oil?
Old Aug 7, 2018 | 9:32 PM
  #16
Good points! They said that R-134A was safer for the environment, but now they have to come out with a new refrigerant?
Guess I'll buy a bottle of R-134A before they jack the prices up on that too.
Old Aug 8, 2018 | 12:43 AM
  #17
if there is a tag on the compressor...follow the instructions...if no tag...follow service information on oil balancing.
if the old compressor detonated on the inside...you need to change the accumulator or receiver drier as any metal from the compressor will get into it. you don't want parts of the old compressor to take out the new one.
Old Aug 10, 2018 | 11:21 AM
  #18
Ok got the new compressor in. This will be the third.
1st compressor was grinding, changed it with a used compressor, replaced the condenser (new) drier (new) orifice tube (new) cycling switch (new)
then the used compressor turned out to be leaking from the housing (according to a AC specialist)
so now I have the brand new compressor and no it doesn't have tags on it, I bought it from eBay and this is what was in their detailed section.
This compressor contains 1.5oz of oil for testing purposes only. Please flush it out and replace it with new oil before installation.
- Every compressor holds a different amount and different type of oil. (Please refer here.) Please consult a certified technician to confirm the correct type and amount of oil that is needed for your specific vehicle.
- You will completely need to flush all fluids from the system and the compressor before it is installed.
So what do I need to do to flush out the oil from the new compressor? And I have pag oil in the system from before. Thanks God bless u guys.
Old Aug 10, 2018 | 8:45 PM
  #19
how much oil came out of the old compressor...drain it out and measure it.
Old Aug 10, 2018 | 11:57 PM
  #20
Same amount. Everything is good on oil. But after pulling vacuum today I tried to add refrigerant and it just wouldn't go in the system. It was at a standstill. After trying to get two cans to go in the system I ditched the gauges and added the 3rd can with a small hose that comes with the large disposable cans. I don't know what's up with the gauges I don't think they're good. I don't know how much my pressure is now. I will buy one of them hoses with the built in gauge.
