BAD coolant leak
BAD coolant leak
My daily driver (01 Impala) has a coolant leak (about 1gal every 2-3 months in warm weather) And now that it has gotten cold the leak is worse (About 1gal a week) the only difference is the weather and the fact that i have the heater on.
Smoke billowes out of the driver's side of the engine compartment and you can see coolant dripping off of the frame (unibody/ whatever).
Can you give me any pointers? (I have already changed the gasket on the thermostat housing because it had a small leak.)
And there is brown crud on the radiator cap.
Your leak has the same symptoms as my 2005, but I've failed to pinpoint it. I initially thought it was a shaft seal on the water pump or the pump gasket, but that doesn't seem to leak though coolant is all around the area.
I let it go too long and experienced some mild overheating. Upon refilling it, I found my heater doesn't work. I was told there's an air relief plug somewhere, but I can't find it. Anyone know where it is?
jsepps
March 29th, 2014 5:44 PM
tcr1016
October 25th, 2011 6:41 PM
