2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Bose Soumd System
Old Nov 12, 2013 | 3:58 PM
RJM1962's Avatar
Default Bose Soumd System
I have an Impala LTZ 2012 with the Bose sound system. When I accelerate it gets louder and when I decelerate it gets softer. It is pretty annoying to keep changing the sound levels. Is this normal or is there an adjustment I can make.
Old Nov 12, 2013 | 5:41 PM
Official GM Rep
Hi RJM1962,
I apologize if this has become a bothersome characteristic in your vehicle. Some models have the Speed Compensated Volume (SCV) feature. This will automatically adjust the radio volume to compensate for road and wind noise as the vehicle speeds up or slows down, so that the volume level is consistent. To activate SCV:
1. Set the radio volume to the desired level.
2. Press MENU to display the radio setup menu.
3. Press the softkey under the AUTO VOLUM tab on the radio display.Press the softkey under the desired Speed Compensated Volume setting (OFF, Low, Med, or High) to select the level of radio volume compensation.
The display times out after approximately 10 seconds. Each higher setting allows for more radio volume compensation at faster vehicle speeds.
I hope this helps. You can find more information regarding your Infotainment system in the vehicle Owners Manual in Chapter 7-4. Let me know if this works!
Amber N.
Chevrolet Customer Care
Old Nov 13, 2013 | 11:13 AM
RJM1962's Avatar
Originally Posted by Chevrolet Customer Service
Hi RJM1962,
Amber N.
Dear Amber,
You were right on. I followed your instructions and found out it was set to high. I set it to low and now no pronounced fading. Thanks again! I never even knew that was an option!
Old Nov 13, 2013 | 9:22 PM
Official GM Rep
Dear Amber,
Excellent! I'm glad this solved your problem! Please let me know if you have any other concerns. I'm more than happy to help!
Cheers
Amber N.
rahb0sse
May 2, 2011 12:06 AM
vette40509
Mar 5, 2010 10:29 AM
latif99
Jul 4, 2009 6:22 PM
fakhir1234
Feb 27, 2009 7:41 PM
gus_gus18
Mar 21, 2005 9:26 PM
