2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Engine Code P0449 Chevy impala
Old Aug 9, 2013 | 8:05 AM
rjbonin's Avatar
Default Engine Code P0449 Chevy impala
I have a chevy impala 2006 6 cyl 3.5 engine keep getting engine code p0449. I already changed the gas cap anyone have futher suggestions if it could be the selinoid
thanks
Old Aug 9, 2013 | 9:14 PM
if the code is for a large evap leak, I would check the canister vent valve.
Old Aug 25, 2013 | 8:46 AM
Joe Baker's Avatar
Check & see what your voltage is at the 02 sensors as well. My 02 B1S1 was bouncing from 0.4v - 0.7v
Old Aug 26, 2013 | 11:02 AM
rjbonin's Avatar
Default Impapla
Thank You, I will check both those
Old Aug 27, 2013 | 8:57 PM
p0449 is a dtc that sets when there is a fault in the evap vent solenoid circuit.
the instrument panel fuse box supplies current to the vent solenoid. with the key in run check for battery voltage on the red/white wire at the connector to the solenoid. the white wire goes the ecm and the ecm supplies grd to close the valve. the valve normal position is open.
if you supply the grd to the solenoid it should close the valve and you should here a click. disconnecting the grd should release the valve and you should here a click as it opens. if its not clicking, the valve is probably bad.
Old Nov 18, 2013 | 1:37 PM
Katcountry54's Avatar
I have a 2006 Impala, 3.9 v-6. My check engine light came on and coded p0449. How can I find out exactly what caused that? It runs fine, but I want to know what is wrong so I don't get stranded somewhere. Helppp Thanks
Old Nov 19, 2013 | 6:53 AM
performing the testing I have already posted will determine the fault.
07tahoe
Apr 29, 2016 10:55 PM
fishing nut
May 6, 2015 10:14 PM
phllyd04
Sep 7, 2011 6:48 PM
Donaldd
Jun 28, 2010 11:11 AM
XiBowhunter
Mar 22, 2010 12:29 PM
