2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
brake problems, need help
Old Oct 2, 2020 | 7:25 PM
young2886's Avatar
Default brake problems, need help
I have a 2007 impala 3.9. I recently put in a new master cylinder due to pedal going to the floor. I bench bled the master and then proceeded to go through the proper brake bleeding procedure with the scan tool. After bleeding brakes I have a brake pedal, then when I start the car the pedal goes away and the pedal loses all pressure. not sure if i need a new ABS module or what to try next. any help would be much appreciated. thanks in advance
Old Oct 11, 2020 | 9:13 PM
chevyboy@22's Avatar
Default Brake problems for Impala
Start your engine, but keep it in Park with the parking brake on. (If your vehicle doesn’t have power brakes, it’s okay to do this check with the engine off.)
Old Oct 14, 2020 | 6:59 PM
young2886's Avatar
ok and what is this going to accomplish?
Old Oct 14, 2020 | 7:38 PM
kevinkpk's Avatar
You should have an abs light if you have an abs issue.
Old Oct 15, 2020 | 8:23 PM
Probably brake fluid leaking
Old Oct 18, 2020 | 5:03 PM
young2886's Avatar
thats what i figured, ive done all the processes right and still i am losing the pedal after bleeding. i had a broken line and replaced it. and i cant see fluid leaking anywhere else
Mattpeterson01
1988 - 1998 (GMT400)
Jul 18, 2019 5:31 PM
Erik Holmes
Mar 26, 2018 8:26 AM
joe0072
Sep 23, 2017 10:41 AM
blj0hnst0n
Apr 17, 2013 1:55 AM
tillett70
Aug 10, 2011 5:25 PM
