2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Chevy impala 2010 p2444 code keeps coming on
Old Apr 4, 2021 | 7:45 AM
Frankie James's Avatar
Default Chevy impala 2010 p2444 code keeps coming on
So I have a 2010 Chevy impala LT 3.5 the stupid p2444 code Kees coming back on cold starts I had the air pump replaced as well as the valve relaxed checked the relay I have steady ground babe no idea what to do next my mechanic doesn’t even know what else it could be car runs fine but once I had one of those items replaced and I left it over night then started the car engine light would come on any help please
Old Apr 4, 2021 | 10:14 PM
oilcanhenry's Avatar
I used to have to work on the original AIR system, so I'll be honest and tell you that I hate the AIR systems, but you have to meet smog standards, I understand:
Here is what I found:
What causes the P2444 code?
  • Faulty air injection valve
  • Faulty one-way check valve
  • Faulty air injection pump
  • Faulty pressure sensor
  • Pressure sensor wiring that is frayed, broken, or shorted
  • Pressure sensor connector that is damaged or corroded
  • Pressure sensor connector that has bent pins
  • Faulty vacuum switching valve
  • Vacuum switching valve wiring that is frayed, broken, or shorted
  • Vacuum switching connector that is broken, melted, corroded
  • Vacuum switching connector that has bent pins
Schreiber
Jan 30, 2023 2:48 PM
Nelson J Castillo
Jan 8, 2021 10:10 AM
cbroche10
Cobalt
May 23, 2019 2:03 AM
rodes6
Cobalt
Dec 10, 2013 8:53 PM
Kristi
Jan 28, 2013 3:18 PM
