2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Exhaust finally
Old Jun 12, 2009 | 7:09 PM
bh04's Avatar
Default Exhaust finally
Once I get an idea of what would be better i'm going to place my order hopefully soon.
I'm doing exhuast hopefully next week, and I cant decide on what mufflers I should go with. No one around here has my same impala with exhuast.
I can't decide between these Flowmaster's:
Super 40's
Standard 40 series
40 series Delta Flow
I have a 2007 SS with the 5.3 (i'm sure you all know that already anyways)
What size piping?
Just from Cat-back?
Get rid of catalytic converter and just have a test pipe done?
Should I do a bigger down pipe?
Reccommendations will be very helpful
Old Jun 12, 2009 | 11:39 PM
Mike Sigmond's Avatar
ROTM Coordinator
If your motor is stock, I would just do a simple cat back system. I want a new muffler too, just still deciding on what to go with.
Old Jun 13, 2009 | 5:57 AM
HotSauce6226's Avatar
Impala Super Moderator
Super 40's
Standard 40 series
What size piping?
Just from Cat-back?
Depends on what you want out of the car, looks or performance.
40 series will be loud, but on a v8 it should be ok. I like magnaflow myself.
Are you buying a cat back or having a shop do it for you?
Stock piping is 2.25, id go with 2.5 mandrel bent if possible.
A bigger down pipe would be benificial. Id keep the cat for emissions testing. If you had teh cat off youd also throw a code.
Old Jun 13, 2009 | 4:43 PM
bh04's Avatar
Question
Obviously i'm looking for some performance gains. A local exhaust shop will be doing it for me. I'll be going 2.5 inch piping. Also, what size downpipe? 2.5 inch? I will also be getting a hi flow cat as well.
So 40 series or Super 40 series? Grrrr I cant decide
EDIT: Not to long from now, I will also be getting a Cold Air intake....probably next paycheck.
Old Jun 13, 2009 | 8:22 PM
ROTM Coordinator
Are you aware that if you want a real performance boost you have to chip the computer? the new exaust & intake will sound good but it wont have more power until the ECM is reprogrammed to account for the upgrades.
Just my 2 cents
Old Jun 13, 2009 | 8:26 PM
2.5 sounds fine.
The HF cat will set off a CEL im sure. Might have to get that code deleted from the pcm/
Old Jun 13, 2009 | 8:28 PM
Just my 2 cents
The Impala's dont have "chips" We can reprogram the PCM or tune it. Thats what I have done. You can change things like timing, shift skips, octane gas, rev limiters and speed limiters.
I would get the tune last after all my mods so I can tune to that
Old Jun 13, 2009 | 8:36 PM
ROTM Coordinator
Thanks for the correction, thats what I meant, you dont have to buy a chip.
Old Jun 13, 2009 | 10:14 PM
bh04's Avatar
Here is what i've got so far from you helpful folk.
I've decided to get Flowmaster 40 series.
I've decided to get 2.5" piping from cat back.
I've decided to get a 2.5" downpipe.
I did notice i have to cylinder looking things uner my car...i know one is my cat what's the other one?
I have no idea where to get my car tuned is the only downfall nor do i know how myself.
Old Jun 14, 2009 | 12:48 AM
One is the cat (closest to the engine) other is a resonator ( closer to the back)
You can get the dp from hogan i think. you need a diablo or hp tuners to tune it...hard to find
