2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Old Jul 24, 2015, 4:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Finally a cheap passlock fix!
Old Oct 30, 2018 | 5:23 PM
  #331
Michael Gentile's Avatar
Default 2004 gmc savanna 2500
Originally Posted by sherryberryhb
I need help to see if I can do this myself. single mom with no money. please help. Thank You
can you send me instructions in bypassing the passlockon this vehicle
Old Dec 7, 2018 | 2:43 AM
  #332
Dan L. Dornack's Avatar
Default Please and Thank You,
Originally Posted by Dertman420
. Please send me the diagram Brian@midatlanticmobile.com
I have a 2001 monte carlo, if this will cross reference,
please send me the diagram Jiwdan512@gmail.com
Old Dec 18, 2018 | 1:56 AM
  #333
Terrence Young's Avatar
Originally Posted by mobileinstaller
ok first off changing the ignition switch and tumblers will do absolutely nothing sorry if you have already done this. there are three main components to the passlock II system the passlock sensor, the BCM, and the Ecm and of course the wiring in between. Odds are if this keeps happening and there is no other problems such as door locks freaking out trunk release just goin off then it's not the bcm if you do the relearn feature and it works the it is also not the Ecm. so you are left with the 3 wires that run from the bcm to the passlock sensor.odds are the passlock sensor is bad. now there are two solutions either go to the dealer and have the sensor replaced or bypass the system for good. any respectable mobile electonics installer should be able to do this no problem it takes me about 20 mins and i personally charge 40 dollars to do so hope this helps also if you are mechanically inclined in electronics i can send a diagram on how to bypass it yourself hope this all helps
how do I do it can you send it to me plz
Old Dec 22, 2018 | 11:51 AM
  #334
Garen Niemeyer's Avatar
Default Please
Could you please send me the diagram on how to bypass...thank you very much
QUOTE=mobileinstaller;133910]ok first off changing the ignition switch and tumblers will do absolutely nothing sorry if you have already done this. there are three main components to the passlock II system the passlock sensor, the BCM, and the Ecm and of course the wiring in between. Odds are if this keeps happening and there is no other problems such as door locks freaking out trunk release just goin off then it's not the bcm if you do the relearn feature and it works the it is also not the Ecm. so you are left with the 3 wires that run from the bcm to the passlock sensor.odds are the passlock sensor is bad. now there are two solutions either go to the dealer and have the sensor replaced or bypass the system for good. any respectable mobile electonics installer should be able to do this no problem it takes me about 20 mins and i personally charge 40 dollars to do so hope this helps also if you are mechanically inclined in electronics i can send a diagram on how to bypass it yourself hope this all helps[/QUOTE]
Old Dec 26, 2018 | 12:06 AM
  #335
Diane Halle456789xyzabcdefgh's Avatar
A year ago, I had a problem starting my car . When I put the key in the ignition, the engine wouldn’t turn. I knew there wasn’t a problem with the battery because my lights, radio, etc. were still operating fine. Instead, I got a bright flashing “SECURITY” message on the front panel of the car. After a few minutes pacing around the parking lot, I returned to my car and it started without a problem. I checked online, and several car forums and articles claimed that this was a common problem in 2004 Chevrolet Impalas: some faulty wiring in the security system would stop the car from turning on because it thought you were trying to hot-wire the vehicle.
Old Jan 11, 2019 | 6:19 PM
  #336
Rita Varner's Avatar
please send me the diagram, thanks rita
Old Jan 25, 2019 | 11:58 AM
  #337
Jen Tindall's Avatar
Default Passlock byoass
Can u send me this diagram please , I've unplugged all 3 pigtails but the small auromatiabypass with a button is still plugged in
Thanks!
Old Apr 20, 2019 | 8:11 PM
  #338
wabash15's Avatar
Please send me switch removal /contact cleaning procedures. wep515@gmail.com. Much Appreciated!!
Old Jul 23, 2019 | 9:36 AM
  #339
Joe Spiffy's Avatar
Default pls. send diaggram! :gigtmfe@yahoo.com
Originally Posted by alreadyplayedout
hey Mobileinstaller, could you send me the diagram on the passlock bypass that would work on my 2000 impala? thank you for your time.
Please, send diagram! send to: gigtmfe@yahoo.com Thanx!
Old Jul 23, 2019 | 9:40 AM
  #340
Joe Spiffy's Avatar
Thanks!
Forgot to mention vehicle for Bt-pass Diagram! 97 Olds Achieva
Pls. send info to: gigtmfe@yahoo.com
again, Thank you!
