2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Gas odor when starting
Old Nov 20, 2007 | 12:32 PM
rlbrow03's Avatar
Default Gas odor when starting
I ahve a 05 Impala w/3400 v6 When I start the car I get a gas smell. I don't see any leaks,, have replaced the fuel filter and the vacume hose to the PVC vacume regulator. Could it be the fuel pressure regulaort or a leaky o-ring on an ejector?
Old Nov 20, 2007 | 2:45 PM
rbarrios's Avatar
Default RE: Gas odor when starting
hmmm
where do you live?
ive recently seen alot of post on a trailblazer forum. and mostly vehicles about 3-5 yrs old.
where they are getting gas smell.
turns out that most of these guys live in areas where the roads are salted for ice.
the salt has corroded the area where the fuel pump attaches to the tank, and it leaks.
most report no gas on the ground- but can smell it.
is the smell inside the car too?
if it is....
have you recently had a stereo installed, stereo/amplifier combo installed?
My brother had an amplifier installed in his saturn some years back.
soon after that he started getting a smell of gas inside and outside,
turns out the installers used some big screws to hold down the amp............and drilled right into the tank
when the tank was full, it would smell strongly.... since the fuel was leaking thru there.
amp was installed in the trunk. but because of the fuel tank design..........
Old Jan 25, 2008 | 6:57 PM
jbosque's Avatar
It happened to me once in a while. It was my fuel preesure regulator leaking slightly on start-ups. Cost about $60 at Autozone. Not too har to change.
ahearnm
Mar 19, 2023 6:37 PM
irene91744
Cruze
10
Oct 9, 2022 4:27 AM
norrislaketn
Sep 22, 2009 10:19 AM
ourblackmad
Apr 29, 2008 1:35 PM
ZX1100F1
Feb 28, 2007 9:06 PM
