2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
help 2013 impala fuel system problem
Old Nov 5, 2018 | 2:13 PM
bigwood t's Avatar
Default help 2013 impala fuel system problem
Hey folks im new to this forum. have a 2013 impala that has run great til now. Last week I got a no start, cranks but wont start. checked codes and got a P069E and P023F secondary fuel pump open condition. Looking into prob I discovered 2013 doesnt have a FP relay so im a little lost on diagnosing the prob. I jumped the pump and it works, so went next to fpcm and found its getting 12 v where needed but Im not sure if the 2.4v im getting from the pcm connection to the FPCM is ok. I havent worked electrical probs often so im worried about ruining a component. I was gonna jump the fuel pump ground and crank the engine to see if the prob is on the ground side but I wasnt sure if that'd work or maybe screw something up cause i think the FP is controlled by connecting and disconnecting the ground side circuit.
Thanks for reading!
Old Nov 27, 2018 | 6:38 PM
Frank3's Avatar
Hi bigwood t, welcome to the forum. Have you gotten this running yet? Can you get it scanned to see if any codes are present?
Old Nov 27, 2018 | 10:10 PM
post your engine size...then I can check the diagnostics for the 2 codes.
Old Jan 1, 2022 | 3:39 PM
newagemechanic78's Avatar
Thanks for reading!
Ok so you have 2.5 volts coming from your 5 volt reference so issue is more than likely the relay pwr trn relay id check there first then the pcm remote wire
bowz91
Jun 14, 2018 6:03 PM
Killerwoody
Mar 4, 2018 3:58 PM
den052
Feb 27, 2018 6:52 PM
akmechanic
Jun 24, 2017 5:29 AM
sirocco110
13
Jul 24, 2016 2:55 PM
