2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
HVAC actuators
Old Jul 15, 2017 | 2:44 PM
J C Smith's Avatar
Default HVAC actuators
I have a 2007 Impala , dual climate control. I know there is one on drivers side and three on passenger side. Can anyone tell me if all 4 actuators are the same part number? My fresh air/ recirculate actuator broke, now I'm hearing the dreaded clicking noise just left of the radio. I want to fix both at same time. Dorman part 604-108 supposedly covers all 4 actuators. Is this true? Appreciate any input.
Chris
Old Jan 17, 2018 | 8:51 AM
J C Smith's Avatar
Really ? No one has ever replaced blend doors or recirculation door actuator motors? Again, appreciate any info. What I need to know is ,does the computer calibrate new actuator motors when engine is started and AC is turned on ?
Chris
Old Jan 17, 2018 | 8:17 PM
they should all be the same. call the dealer parts debt and ask.
Old Jan 21, 2018 | 8:25 PM
J C Smith's Avatar
tech 2, thanks for the input. All 4 are indeed the same part. But, does the computer calibrate each actuator upon engine start up or is that not a concern?
Chris
Old Jan 23, 2018 | 8:33 PM
I can't say for every model. Mthe one's i have installed did not self calibrate. most require a scan tool. the trucks could calibrate by pressing the recirc and ac buttons 3x...the leds would flash during calibration.
if on start up the doors cycle on their own...it needs calibration.
Old Jan 26, 2018 | 9:41 AM
J C Smith's Avatar
tech2 , thanks again for the info.
Chris
Old Feb 1, 2018 | 8:27 AM
J C Smith's Avatar
I want to clear up a mistake I made. There are 3, not 4 actuators that are the same.I have dual climate control. The recirculation and left and right blend door actuators are the same. The mode actuator is different. Hope I didn't confuse anyone who read this thread.
The dealer charges way too much for this job.If you have normal size hands you should be able to accomplish all three without too much cussing.Moving wire harnesses out of the way helps alot. Also lining up the new actuators can be done with 2 jumpers and a 9 volt battery so the 2 screw holes will line up. When I took the old ones out I tried to duplicate the position to the new one , but it took a few tries to get right.
I hope this helps.
Chris
Old Feb 3, 2018 | 7:34 PM
9v battery works or remove the actuator cover and center the gear drive so its aligned with the arrow on the cover.
Old Feb 7, 2018 | 11:47 AM
J C Smith's Avatar
tech2, thanks again for the info.I don't see an arrow, but I do see a line next to the output.Might this be what you're referring to?
Chris
Old Apr 11, 2021 | 10:06 AM
Amanda Henderson's Avatar
I have a 06 Monte Carlo and all 3 of my blend door actuators are ticking. How do I tell which one is the main one? Do I need to replace all 3?
