K&N Air Filter on '03 Impala LS - Are there any Pros & Cons to putting one in??
#21
^^^ NVM. I saw you got it taken care of. The float for the coolant is also an issue sometimes so. Result to that as well if you ever get a random low coolant light.
Still I would double check to make sure there is no crack in the reservoir. Like I said, it may have sprayed out on to the sensor and is no issue. But double check to be safe.
#22
92Stepside
June 14th, 2009 6:00 AM
