low oil pressure lite & warning
Hyflyer, I presume you have a V6? I have the 3.5 flex fuel engine. The 3.9 V6 is not as common ,so I don't know much about it , but it is probably similar. if you have that. Glad I could help someone. I try to do most of my own car repairs, thus saving money that could go towards beer or other toys. LOL. Good luck, hope that does the trick. Chris
On the 3.9, changing this part required a special socket and two long extensions. Put the socket on the oil pressure switch and ran the extensions across the front if the motor where I had room to turn the 3/8" ratchet. Honestly the hardest part was trying to squeeze my hands into position to reconnect the harness.
Does anyone know the proper way to get at this sensor. I read to remove oil filter then sensor. Can't get at it from underneath. I managed to loosen it from above after removing exhaust heat shield and top motor mount. Just can't get my hand on it to remove it. I have a 27mm motorcycle axle wrench that I just barely was able to loosen it with. The problem is going to be getting the new one's threads started . I'm thinking the starter may have to come out. Any thoughts anyone? TIA Chris
Dont worry about getting leaverage when installing it. The torque is lower than the drain plug 12ftb.
not_a_car_dude
Sep 15, 2013 7:41 PM
Crew Cab Kevin
11
Jul 1, 2012 1:52 AM
