2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Misfire after replacing oil pressure sensor on 07’ LTZ
Old Mar 3, 2019 | 6:11 PM
Justin Pelan's Avatar
Default Misfire after replacing oil pressure sensor on 07’ LTZ
So I replaced the oil pressure sensor on an 07’ Impala LTZ with the 3.9L and was satisfied to have remote start working again. Took it out for a test drive to see if the AFM was working and 2 minutes into the drive coming to a stop light the car suddenly bogged down and the check engine light starts flashing. Misfire, P0300. Now runs like a tractor with an intermittent (every 3 seconds or so) tapping valve noise, and backfires with heavy gas applied.
Did an AFM lifter collapse? Cylinder 6 isn’t firing, pulled that plug wire off while running and the motor didn’t sound any different. Tried unplugging the oil pressure sensor wire and disconnecting the battery, no help...
Any ideas to get this thing going again?
Old Mar 3, 2019 | 8:01 PM
oilcanhenry's Avatar
You getting a code P0521 ?
Old Mar 3, 2019 | 8:42 PM
p0522, misfire persists whether or not it is plugged in.
Old Mar 3, 2019 | 8:47 PM
Here are some live readings
Old Nov 7, 2023 | 4:21 PM
Dakota_Don's Avatar
did find the issue ??? I just had the same thing happen on a 08 3.9
Old Nov 7, 2023 | 5:03 PM
@Dakota_Don that person hasn't visited the forum in 4.5 years. You're better off making a new topic and explaining your situation.
doktrred
Feb 4, 2024 2:46 PM
jqwest
Aug 23, 2019 1:27 PM
MarlinL
2007 - 2013 (GMT900)
Mar 8, 2019 5:46 AM
Cooky97
Jul 9, 2018 12:19 AM
RBurley
Mar 9, 2015 9:25 PM
