2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Need help - 2004 Impala transmission won't go in reverse
Old Nov 20, 2011 | 6:50 PM
Jason Price's Avatar
Default Need help - 2004 Impala transmission won't go in reverse
My transmission was shifting hard when going from park into any other gear. One day it decided not to shift into reverse. In fact it was acting more like it was in neutral. After shifting back and forth several times between other gears and reverse it suddenly engaged - good enough to get me out of my parking space and on my way home. Once home it would not shift into reverse at all - still acting like it was in neutral.
I figured I would change the tranny fluid and filter hoping that it would help. After that the transmission would still engage in drive with a noticeable thunking sound and jerk, but reverse is still not engaging. When in reverse I can physically push the Impala forward and back as if it were in neutral. I do hear a bit of a whining noise when in either 1st gear or reverse. 1st gear appears to still work fine though. There are no warning lights on the dash either.
Any help anybody can provide would be most greatly appreciated. I'm not sure what additional information to provide.
Old Nov 21, 2011 | 12:33 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I am sorry to hear of your frustrations with your vehicle. Is this a new issue? How often does it occur? Have you had the opportunity to take it to your dealer for an inspection? I look forward to your response.
Louis
GM Customer Service
Old Dec 1, 2011 | 11:52 AM
barry4219's Avatar
sound like its rebuild time .Take it to a transmission shop it is probably going to need completely rebuilt . been there done that . Good luck
igloo
Sep 7, 2011 3:09 PM
Buck Shaw
Jul 1, 2011 3:30 PM
samger2
Aug 11, 2009 11:49 PM
