2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Oil in Coolant
Old Sep 16, 2012 | 12:19 AM
Eggie329's Avatar
Default Oil in Coolant
I have a 2001 Impala with the 3800 engine and 68,000 miles on it with a fairly new crate engine before I got it at 58,000. After a long series of problems, I learned that my upper intake gasket was bad.
Seeing as the engine is quite new we assumed the lower gaskets were fine. A week of no issues and it is back to running rough and now I also had oil in the coolant which wasn't happening before. I also know that the upper gasket is already bad and melted at the EGR tube despite being a high performance manifold and gasket.
Is it safe to assume that it is lower intake time already? What can I do to make the gaskets stop leaking? All I am trying to do is keep this darn car running for one week to sell it, but everyday it is a new problem.
I guess I just find it hard to believe that GM made a car that can't stay running for a week. It is already on it's second engine and FOURTH transmission (fortunately the last two were under warranty). Every GM truck I have had has never had problems like this.
Thanks for any help.
Old Sep 16, 2012 | 7:38 AM
junkman104's Avatar
My first quick thought was are you sure if it is engine oil or transmission fuid in the coolant? I have seen trans coolers in the radiator tank leak into the coolant before.
Old Sep 16, 2012 | 8:44 PM
MDTAHOE's Avatar
Professional Mechanic
Did you replace the upper intake or just the gaskets? It should have been replaced as an assembly as they warp by the EGR pipe. Dorman make a complete intake assembly that comes with everything need to do the job. It comes with a replacement EGR pipe that is smaller in diameter, which fixes the problem.
dlaroche
Oct 29, 2014 7:17 PM
Eric Sherden
Sep 24, 2013 1:21 PM
grndslm
Dec 18, 2012 2:38 AM
blkclipse
May 24, 2008 8:15 PM
larry_chip
Apr 24, 2007 11:46 AM
