2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
oil pressure sensor location? - 2005 Impala LS
Old Dec 13, 2015 | 2:42 PM
johnnyzero's Avatar
Default oil pressure sensor location? - 2005 Impala LS
Can anyone tell me the location of the oil pressure sensor on a 2005 Impala LS (3.8L V6 VIN:K)? Or better yet, a diagram link that shows the location?
Also, should I drain the oil before replacing the sensor? I assume that oil might pour out of the sensor port during replacement.
thanks,
JohnB
Old Dec 13, 2015 | 9:32 PM
U.Nanimous's Avatar
It is in the place that makes the most sense...within inches of the oil filter.
Item #431
Bookmark that website, they have tons of parts diagrams.
Oh...if you let the car sit a while, most of the oil will be in the pan with the exception of what's in the filter. I don't think you'll lose much oil if any when you pull the sensor out, but I haven't changed one yet so be prepared with a rag in case I'm wrong.
Old Dec 14, 2015 | 4:01 PM
johnnyzero's Avatar
Thanks!
Swapped the sensor. Fingers crossed that it fixes the intermittent Low Oil Pressure light/alarm.
Old Dec 14, 2015 | 5:09 PM
U.Nanimous's Avatar
A lot easier than changing the pump. If you do that you will have to drain the oil and remove the pan to get to it.
