2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Power adapters and battery
Old Oct 15, 2012 | 5:41 AM
bha19's Avatar
Default Power adapters and battery
My question is under the dash are 2 power adapters on my 2006 Impala LT that I can plug things into. What will happen if I leave them plugged in with the car off? Should I unplug them every time I leave the car? I know the car has battery run down protection at least. On my last car the plugs did not operate unless the key was in the ignition and the car was running.
Old Oct 15, 2012 | 8:12 AM
Nicky Nine-Piece Massino's Avatar
I'm not really 100% sure.... I had a Durango before my Imp, and it required the ignition to be turned a least to "ACC" to work, but this is not so with the Impala. My wife uses one plug for an adapter to charge her iPhone and constantly leaves it plugged in, & u can see the little green power indicator light on top of the adapter is still on. We've had this impala for a couple months now, and that adapter is left in on a daily basis. I'm talkin overnight from like 5 pm til 8 am or so the next day, but it's never died and I've never noticed any power drain or difficulty starting up the next day. But it still makes me nervous. I would still recommend unplugging any accessories, but from experience I can tell you if you forget from time to time, yo should still be ok..... Unless the batteries like suuuuuper old and worn out....
Old Nov 10, 2012 | 9:29 AM
40_Cal's Avatar
Thumbs up It's Fine
I've had my Impala for about a year and a half. I leave my charger plugged in all day and night. The system is set by the factory to cut out at <12 volts. I found that out by leaving my leds on for three days straight by accident. Yes three days. At worst the interior lights and accessories will not come on until you crank the car up. It is a protective measure. The Impala cranks out more than enough to recomp when you fire it up the next day
Old Nov 10, 2012 | 12:56 PM
the bcm operates the run down protection and only opens the interior light and exterior light circuits.
The power outlets are powered directly from the underhood and instrument panel fuse blocks and are NOT bcm controlled and do not have any run down protection.
the 2 outlet circuit fuses are 25 and 20 amps so depending on what the component connected draws; there is potential to discharge a battery overnight.
What are you plugging in and what amp current draw does it say on the component adapter plug?
Old Nov 11, 2012 | 7:12 AM
bha19's Avatar
It says Input / Output: 9-16 V DC / 5 V DC, 1.5 A, but it is an XM Edge radio that plugs into the AUX on the radio and the supplied power adapter.
Old Nov 12, 2012 | 8:16 PM
power off the xm radio and you will be fine. A 1.5 amp draw will kill a battery overnight.
New_To_Suburban
Nov 24, 2011 10:34 AM
Deltavox
Feb 22, 2011 6:44 PM
jeff618
Feb 10, 2011 10:00 AM
jrsavoie
Jan 15, 2011 3:11 PM
kizzelwhix
Mar 21, 2010 8:37 PM
