2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Radio problems
Old Mar 14, 2022 | 3:14 AM
snowybanana02's Avatar
Default Radio problems
I have the stock radio and every time I put it on a station i have to turn the volume fully up to hear anything. If i change it up or down by .1 it goes back to normal volume, cd also has normal volume. Its only when I'm on a radio station.
Old Mar 20, 2022 | 11:49 AM
chevyboy@22's Avatar
it needs power to function. It gets its power through a fuse located in the interior fuse panel that can be accessed through the door that sits in front of the drivers left knee. This is usually a 15 or 20 amp fuse in position #4. You must replace it with a fuse of the exact same amperage rating. Another common cause for the radio to stop working is the anti theft system that gets triggered when the power is disconnected for a certain amount of time. The head unit will not power back on until a reset code is entered. You can usually get this reset code by calling or visiting Your local Chevy dealership.
volunteerfarms
Sep 30, 2022 5:07 AM
Axis
Jan 5, 2022 5:35 AM
MNBenny
Aug 24, 2019 12:05 PM
sayed
Apr 12, 2012 11:06 PM
YTYT
Aug 22, 2010 2:23 AM
