Radio problem
Old Jan 3, 2022 | 5:48 PM
Axis's Avatar
Default Radio problem
Hi I have a 2014 suburban and the Bose radio started acting wierd only the cd player and satellite part work and sometimes the aux works but it is intermittent should radio be replaced or can it be fixed
Old Jan 4, 2022 | 8:13 AM
Welcome from Florida. How old is the radio? It can probably be repaired but is it worth the cost of repair when a bit more can get a new radio. It might be something simple and it may be more complicated.
Old Jan 4, 2022 | 8:46 AM
Axis's Avatar
Default Radio
It is the stock radio from 2014 its the Bose kit the came with it . It seems like lost everything that works off the antenna wonder if clock spring could also be issue there are radio controls on the steering wheel as well
Old Jan 5, 2022 | 5:35 AM
repairman54's Avatar
AM / FM antenna is in the passenger side back window. Satellite antenna is in the shark fin as is the cellular antenna.
96 Junk That Moves
Oct 26, 2015 7:32 AM
wing98
Jul 14, 2014 6:43 PM
parkb309
Jan 25, 2013 12:28 PM
bobw
Sep 22, 2008 1:19 AM
