2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Service air bag warning - possible fix
Old Jun 6, 2014 | 9:07 AM
  #11
Frank3's Avatar
The manual states to disconnect the battery to allow the systems to discharge and prevent accidental deployment of the air bag. If I'm not mistaken, the connector on the airbag was supposed to include a shorting clip, so designed that when disconnected, shorts across both pins thereby preventing discharge of the bag. If the wires are cut and soldered, then this would remove the protection device.
Old Jun 6, 2014 | 7:43 PM
  #12
disconnecting the battery, then waiting for 10mins for the capacitors to discharge is the proper way. buy some dielectric grease; its cheap and may save you repeat repairs.
Old Jun 6, 2014 | 10:19 PM
  #13
sledge.impy's Avatar
I was changing my radiator fan in a 2002 j-body once.. without disconnecting the battery.
Anyways - after removing the radiator support my abs sensor was shaken to hell and back.. "BOOOIINNNGGG" type... lol
Even though I did some research - the newer sensor require other sensors or movement to activate air bags, I started the car from the rear seat behind the driver seat with ear plugs in.. lol
Old Jun 6, 2014 | 11:04 PM
  #14
2 sensors must trip for an airbag module to deploy. the first is the impact sensor located at the perimeter of the car. the 2nd is the safeing sensor or sdm located in a central location in the vehicle. if only one goes off...no deployment. If current is induced into the deployment loop then all bets are off.
Old Jun 6, 2014 | 11:23 PM
  #15
Thanks for clarification.
jentoe91
Apr 21, 2017 9:14 PM
AK__21
Apr 24, 2013 7:25 AM
elcalote99
Nov 12, 2009 9:00 PM
bhearn
Oct 12, 2009 7:31 AM
Chevylover247
Jan 15, 2009 5:38 PM
