spark plug wire confusion
Hello,
while I was working on my 85 5.0 Impala i noticed the plug wires were mixed up (1,2,7,5,6,3,4,8) so I plugged them back to the original (1,8,4,3,6,5,7,2) sbc firing order as listed on my intake. It sprayed gas out of the carb uhh ohh!
It was running good on the mixed up wires I just thought the timing was weird on it
So does that mean since it sprayed out of the carb the dizzy is 180° out?
And I looked up 12756348 on Google and that's the reverse firing order
What should I do?
What should I do?
So if you follow the firing order cast on the intake, and match the cylinder with the distributor cap, all around 8 cylinders it will be correct if it is a sbc. The cylinder order is facing the fron of the engine right side first is 1, 3, 5, 7. Left side is front 2, 4, 6 8.
So something has to be backwards.....like the dizzy being 180° out
Esc?
It has to be on the compression stroke because #1 is the same place for both firing order configurations, it never backfired or threw gas out if the carb for the reverse one
