2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Stalls at red light
Old May 19, 2024 | 9:31 PM
  #11
chevelle1989's Avatar
@mouontainmanjoe
I don't think I know better that is why I am here asking if it came across that way that is not the case, but I have checked everything with my scanner and everything I can see and test physically and it all checks out. and like I said before the Small Evap Leak code has been there since like the 3rd day I had the car I am suspect that it is the charcoal canister or the purge valve which I have dealt with before on other vehicles and know that will not cause the issue I am having. My issue is that the speedometer bounces all over the place on its own when it is not moving and it is either in gear or in neutral and I will also see a message on the cluster saying vehicle limited to 107MPH and then it stalls you can keep it from stalling only if you have it in neutral and just about floor the gas pedal then it will stay running but will spit sputter and pop like crazy and just plain run like garbage. From the research I did to begin with before coming here had shown and lead to The Transmission/Vehicle Output Speed sensor which is just beyond the passenger side CV Axle on top of the transmission, I have changed this part with no change to the issue. I am just asking anyone if there is anyone out there in the forum that may have came across or possibly had this problem before and resolved it what the cause and what repair was done to fix it.
Old May 19, 2024 | 11:01 PM
  #12
So why didn't you fix it? The engine needs a good vacuum to run properly. Maybe it just finally opened up bad enough to give you issues that you noticed.
I am suspect that it is the... purge valve
The purge valve seals your intake against the EVAP system. If it leaks then you have unexpected air entering the engine.
The valve needs to work properly for your engine to work right. It's that simple. So for the 3rd time .... fix your leak.
My issue is that the speedometer bounces all over the place. message on the cluster saying vehicle limited to 107MPH and then it stalls
This would have been helpful to mention at the beginning. 🤦‍♂️. What does your vehicle speed read with the diagnostic tool?
Old May 20, 2024 | 9:30 AM
  #13
"So why didn't you fix it? The engine needs a good vacuum to run properly. Maybe it just finally opened up bad enough to give you issues that you noticed."
I just havent got to it yet as I said I am not medicaly well and have alot of appointments plus have family that needs me to get them to medical appointments its just no that easy when you just don't have the time
"The purge valve seals your intake against the EVAP system. If it leaks then you have unexpected air entering the engine.
The valve needs to work properly for your engine to work right. It's that simple. So for the 3rd time .... fix your leak."
I am going to but in the mean time this will not cause what is going on with it now and if I can't get it to stay running its not worth putting out money on something I know is not going to fix my current issue.
"This would have been helpful to mention at the beginning. 🤦‍♂️. What does your vehicle speed read with the diagnostic tool?"
I believe I did mention this in my first post and I can't measure speed as it won't stay running long enough
Old May 20, 2024 | 1:09 PM
  #14
Wrong. Like I explained, vacuum leaks definitely can cause stalling.
so if you "know", then why isn't the problem fixed already?
This makes no sense, since vacuum leaks are so easy to check for and might cost you a $5 piece of hose to fix.
You would rather replace the computer which can cost into the thousands.
One of the first things I asked was if you were receiving any trouble codes . You made no mention of the message on your cluster.
What if you unplug the sensor?
Anyway it seems like you're just here to find people to tell you what you want to hear, and not fix anything. Best of luck to you.
Old May 20, 2024 | 2:27 PM
  #15
Pierregirard's Avatar
You know, if your engine or transmission mounts are worn out or busted, they can cause problems like this. When you shift gears, it can jostle the engine and transmission around, messing up connections or wiring.
Old May 21, 2024 | 9:38 AM
  #16
I am going to double check the wiring later today will look for this as well
Old May 25, 2024 | 11:31 AM
  #17
OK Believe I have found the issue for anyone else that may have a similar issue with a 4T65E transmission check the Torque Converter Clutch Solenoid inside the side cover of the Transmission it can be a pain to get to but not terribly tough. @mountainmanjoe sorry if I came off poorly I only meant that there was no actual vacuum leak to the engine itself that was causing this issue and I didn't want to throw money away on parts to fix an issue that was not causing the main problem just yet. I do thank you though for your help and appreciate your opinion. I have the part on order and fingers, toes, and eyes Crossed this resolves the issue. It is a fairly inexpensive part $20 on amazon would have bought localy but $50 at the auto parts store localy. will report back afterwards the results for anyone who would care to know.
Old May 25, 2024 | 1:02 PM
  #18
There may still be a vacuum leak to your engine, but I'm glad you solved the stalling.
It is a fairly inexpensive part $20 on amazon.
I'm not sure I would install Amazon cheapies for a critical part like that.
Old May 29, 2024 | 12:37 PM
  #19
It is a Dorman branded part not off brand it was like $28 with tax and shipping
Old May 29, 2024 | 12:40 PM
  #20
I'm not 100% sure of it yet the part just got delivered today gonna get it put in this weekend when the weather is better and this cold front has gone through. I hate the north country NY weather.
