2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
transmission issue
Old Sep 1, 2006 | 6:27 PM
canatro's Avatar
Default transmission issue
hello, i am a new member and new to the chevy community so please bear with me. i have an 2000 automatic with 80k. here is my problem:
when i am driving for a long period of time, say 45 mins and on, the check engine light comes on and it feels like the transmission is totally slipping! when i come to a stop and take off again, first gear seems fine until it hits second gear and its like it goes straight to 4th! so i brought it to my mechanic who diagnosed a torque converter problem. so it was replaced. same problem. then the error message was something about a solenoid. the mechanic said the solenoid was in good condition and that it must be a physical problem with the transmission. i should note, when he replaced the torque converter, a few peices of metal were found, ver small peices but nonetheless. so the mechanic wants to take apart the transmission and essentially replace it. does this make sense?
thanks all for your help.
canatro
Old Sep 1, 2006 | 6:42 PM
kcb37's Avatar
Default RE: transmission issue
I would agree with him, as anything other than small shavings are bad. It sounds to me like you have a trannly problem and if you actually had metal pieces in your fluid you do need to rebuild your tranny or will need to soon.
Old Sep 1, 2006 | 8:45 PM
uncle bill's Avatar
Ditto on kcb37's answer. The Transmission should have been gone through when the converter replaced. Sounds like worn out clutches and bands.
silveradoman01
12
Jul 1, 2021 11:14 AM
Coravir
Oct 26, 2019 3:28 PM
hos504
Oct 13, 2010 8:22 PM
BCroninger
Jun 19, 2010 4:06 PM
