2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Water in Passenger floorboard
Old Aug 6, 2007 | 8:40 PM
cbyrd's Avatar
Default Water in Passenger floorboard
I have an 04 Impala SS. I first noticedthepassenger floorboard wet during a rain. I thought it was the seal on the windshield. I took it out todayand it hasn't rained in a week. It was 90 degrees and I noticed water runningdown the passenger side carpet into the floorboard. Does this sound like a problem with the A/C system?
-Thanks
Old Aug 8, 2007 | 4:43 AM
Foxracing's Avatar
Default RE: Water in Passenger floorboard
What most likely has happened is that the rubber weatherstripping under the plastic @ the base of the windshield has slid off. If you remove the wipers and that plastic, underneath you will find the spot where fresh air for the interior cab comes in, theres a air filter and likely a piece of rubber(about 12" to 18" long)that will need to be glued to the small metal edge just above the hole where the air filter is. It acts like a diverter to foce water out of that area. Just had the same problem on a Buick that I own. I just used clear silicone to re-glue it on. Easy fix, hardest part is removing the plastic retainers GM uses to hold down the plastic (at base of windshield) so as not to distroy them. You have to get the center plug pulled up before you can pull out the whole retainer, you'll see what I mean. Doubt it's windshield leaking unless it was just replaced, they glue them in real well now days. Good luck.
Anne
Sep 24, 2018 11:11 AM
bwarner
Feb 1, 2018 8:14 PM
jawja
Nov 11, 2011 2:15 PM
shybabie
Jun 8, 2007 10:46 AM
