2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Water Problem
Old Mar 28, 2010 | 5:44 PM
chiefcarp's Avatar
Default Water Problem
I have a 2004 Impala and I hear water sloshing.
It sounds like it is coming from the passenger side under dash or quarter panel.
Is there a drain some where? If so where?
Thanks
Tim C.
Old Mar 28, 2010 | 10:12 PM
Gwampa's Avatar
Sounds like air in your cooling system and sloshing is in heater coil..or it could be those damn frogs again.
Old Mar 29, 2010 | 7:16 PM
capucine's Avatar
Open your hood and go near the cabin filter. Remove the top plastic over the filter and you will see a rubber molding that fits tight in a groove. This molding prevent the rain water to get in the passager compartment. You will certainly notice that the molding has come off the holding groove. No need to buy a new one just use silicone and replace it in the groove slot. Then your problem will be solved. No more flooding on the carpet.
Old Apr 24, 2010 | 3:10 PM
StevenDeRoche's Avatar
Thanks
Tim C.
Make sure your coolant reservoir level is staying at the same level. If it is dropping you might have a coolant leak at the heater core. Which is on the passenger side and sloshing around in the heater core housing. Make sure your flooring is not wet and smells like coolant. Some heater core housings will not drain completely and "sloshing" can be heard. The fix is replacing the heater core.
tns58
Jul 13, 2015 5:09 PM
86CHEVYC10
Dec 25, 2011 9:16 AM
gunder20
Jun 16, 2010 11:18 AM
86caprice415
May 6, 2010 7:31 AM
Fightn17
10
Apr 8, 2010 12:45 PM
