2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Which water pump?
Old Feb 12, 2025 | 12:07 PM
cribboy52's Avatar
Default Which water pump?
I have a '64 Impala with 454/THM475/9inch:3:25/1 posi. The engine has been completely rebuilt: pistons,rings,cam,bearings.781 heads, etc. I have a new stock water pump. This past summer for some reason it began to run hot, which it didn't do when rebuilt. I have read a bunch on mechanical vs. electric pumps. and how to get the cooling to work right with a new aluminum radiator. My question is should i go with a high flow 60 gpm electric or choose a mechanical pump? Thanks cribboy52
Old Feb 12, 2025 | 1:41 PM
Make sure the pump is the problem first. It could be the radiator, thermostat etc.
Old Feb 12, 2025 | 2:10 PM
Rednucleus's Avatar
With the new radiator, do you have electric fans too? If not do you have a proper shroud for air flow??
Old Feb 12, 2025 | 6:08 PM
cribboy52's Avatar
Both are new, radiator is aluminum 4 core.
Yes electric fans, wired to run all the time.
I don't think the pump is the actual problem.
As long as weather is cool outside temp stays down
It's when the ambient temps are up is when the engine wants to warm up past the 180 mark and stay there.
I did more research this afternoon.
I think a high volume mechanical pump is what i need.
Mostly because the electric ones don't seem to have all the bolt holes i hafta have.
Thank you for the feedback.
Have a lovely evening
cribboy52
Geoff1127
Nov 13, 2019 1:29 PM
Keegansherman
Jun 27, 2017 9:46 PM
Nico0203
Sep 13, 2015 7:44 PM
Doogleass
May 9, 2011 9:21 PM
trevor0520
Dec 20, 2006 5:43 PM
