2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
where can refill my A/C on my 2003 impala,
Old May 14, 2023 | 6:46 PM
rocky10954's Avatar
Arrow where can refill my A/C on my 2003 impala,
hello, can someone tell me and post a picture where can refill my A/C on my 2003 impala,
i do not know where to attach the hose to refill the unit, many thanks,
Old May 15, 2023 | 12:46 AM
MIKES19COLORADO's Avatar
Smile
The Bigger Of The 2.. The Suction Line ..I Assume Refrigerant Is R134a...Follow The Instructions On The Can . Do Not Use The Stuff With Stop Leaks Or Dyes ..Make Sure Your Air Is On High For At least 10 Minutes And Running While You Charge, And Do It Slow , Little Spurts Here And There. Do npt Just Let It Rip. And Do Not Over Charge. That is The Biggest Mistake People Make. Watch A Few Youtube Videos. Im A Certified HVAC TECH At General Motors. 608 And 609 Certified
Old May 15, 2023 | 3:17 PM
14impala_in414's Avatar
look on the fire wall right behind the intake. i belive its in the same spot on the 3400 and 3800.
Old May 15, 2023 | 7:17 PM
oilcanhenry's Avatar
If your A/C system is drained out of R-134A, you'll need to vacuum the air out with an A/C pump, before you add new R-134A. You must get all the air and moisture out of your system, or else it will self-destruct one day. You also will not get a good cold A/C blast in the cab with too much air in the system. Always wear glasses or goggles when working on an A/C system as well.
rocky10954
Nov 29, 2021 6:31 PM
rocky10954
Nov 11, 2021 6:39 AM
woganm
Oct 28, 2014 11:14 PM
thomasng
Jun 25, 2013 8:50 PM
