2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
will not start fustrated
Old Nov 26, 2013 | 7:23 PM
sugardaddy1027's Avatar
Default will not start fustrated
ok here it goes in all its glory. Have a 2002 impala 4 door 3.4L have had problems at times where vehicle will not start before and after driving. Wait 15 min starts. Was driving and radiator sprung a leak overheat barely stopped fixed put antifreeze in drove home everything was fine. Next morning will not start. Turn the key to run dash lights on turn to start dash goes out and nothing relays click i hear. let key go to run and 2-5 seconds click lights on dash come back on. Battery drained checked it and got a good charge same problem as stated. Next day battery dead of course i took cables off to charge put back on and some good sparks come from battery. HHHHHHHEELLLLLPPPPPP Please.
Old Dec 27, 2013 | 5:28 PM
bump please hellllp
Old Dec 27, 2013 | 7:53 PM
sledge.impy's Avatar
Originally Posted by sugardaddy1027
bump please hellllp
Are you sure the battery has enough CCA (cold cranking amps)? Are you in a cold climate?
What does a voltmeter say about the battery ? What are your readings? How old is the battery?
Old Dec 28, 2013 | 8:17 AM
How is the condition of the battery cables at the battery and at the other end. Loose connections and corrosion will cause problems similar to yours.
Old Dec 30, 2013 | 9:24 PM
battery and connections are fine it started up great got it home next day would not start changed the radiator hoping a sensor but no codes. checked all the fuses checked the starter. Check engine being siezed moves great everything checks out but it will not start. lights and everything are good and bright in run cicuit but in crank circuit all goes dead put it in the run circuit 2-3 seconds all dash lights comes on.
Old Dec 30, 2013 | 9:46 PM
cold cranking amps are fine battery is great tested and proven. no corosion
attycda
Dec 27, 2021 12:34 PM
Sparky Sparks
Jan 23, 2019 10:53 AM
Xerklite
Apr 27, 2013 9:14 AM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
bracca
Jul 12, 2009 6:14 PM
