2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Won't start but wait 20 minutes then it starts, But not always.
Old Mar 27, 2017 | 7:51 PM
Wanda63's Avatar
Default Won't start but wait 20 minutes then it starts, But not always.
I have a 2003 Chevy Impala. Sometimes it won't start for no reason, but I found if I move the shifter a little a couple times it started, but it doesn't always start when I move the shifter. I've had it in several times and they can't find the problem. Can someone help me? This has been going on for almost a year and it's making me Nuts. The car has 118,500 miles on it and it was purchased
new by my parents.
Old Mar 27, 2017 | 8:11 PM
kevinkpk's Avatar
Does it crank with the shifter in neutral?
Old Mar 27, 2017 | 10:54 PM
Frank3's Avatar
Welcome Wanda63. When you say it won't start, are you saying it won't crank? Or is it cranking over without starting? Does it appear that the movement of the shifter is more random and may not be connected to the no start condition?
Old Apr 1, 2017 | 3:16 PM
Wanda63's Avatar
Hi kevinpk and Frank3,
It won't crank but the radio and lights work fine. Last time I moved the shifter a couple times, waited 15 minutes, tried again and it started. I've never tried putting it in neutral, as kevinpk suggested, then try to start it. I've had it towed numerous times and it has started a few times after it's been towed to the repair shop. One time I stopped to get gas and when I got back in, it wouldn't start so I moved the shifter and steering wheel but it still wouldn't start so I waited 20 minutes and moved them again then it start.
Old Apr 6, 2017 | 6:57 PM
V12TT's Avatar
If I understand the issue with your car correctly then it has hard time to start when the engine warm or hot but not cold. Is that correct?
If that's the case then the culprit is the camshaft sensor.
