K5 Blazer 1969-1994
Platform: Truck, GMT 400
1972 k5 cranks but does not start
Old Dec 23, 2009 | 8:50 PM
hellspawn4001's Avatar
Default 1972 k5 cranks but does not start
i have a 1972 k5 blazer that will not start recently changed the starter and timing chain it cranks and am now getting spark and fuel and timing is right on the distributor and engine at tdc is right with the gears so what should i do to get it started idk it is a hard problem to figure out just need some ideals so if u have any plz let m know thank you very much
Old Jan 2, 2010 | 12:19 PM
a_plus's Avatar
have u tried to put oil in the sparks plugs to get ur compression
Old Jan 2, 2010 | 5:04 PM
tm4hammer's Avatar
Default timing
go ahead and pull your distributor rotate 180 degrees and drop it back in sounds like your 180 out probably timed it off the wrong valve stroke when you replaced the timing chain happends alot easy to do goodluck
HAMMERGONE!!
Old Feb 14, 2010 | 5:37 PM
72c10gunn's Avatar
did u install the timing chain with the gears lined up right?
bluedrew5091
Jun 25, 2013 12:00 PM
likitysplit
Feb 3, 2013 9:14 AM
shant
Feb 23, 2011 9:08 PM
KunoCorp
Jan 24, 2011 2:19 PM
